Does anyone where I can find some quick release fasteners that will replace all those allen bolts on the fairings that come loose. I've lost two already, and I don't want to spend 2 hours every time I take my fairings off.
I lost one shortly after I picked my bike up. It's covered under the warranty, but that does not help you much right now. I would also like to get Q/R fastners!!Antigravityman79 said:Does anyone where I can find some quick release fasteners that will replace all those allen bolts on the fairings that come loose. I've lost two already, and I don't want to spend 2 hours every time I take my fairings off.
I have extra zues fasteners and retaining clips so I tried a while back. The problem is that the holes in the mounting tabs on the frame are smaller than typical (say 916). Now obviously they could be drilled out a bit and it looks like it would be a fairly easy conversion. I held off for two reasons; I wanted to see what DP came up with & I wasn't prepared to do the paint touch-up on the tabs after they were drilled out and I didn't want to leave bare metal exposed. So, I'm waitingkumacrz said:Is there a specific type for different bikes? I found these though not sure what all is needed for the mod? It's just the d-ring pin and a metal tab to mount to the plastics right?
