1 - 8 of 8 Posts
Dear members i ve a problem regarding rear axle hub....i ve disassemble everything and the axle is stuck inside the hub....anyone ...
What model Ducati?
Thks..
Could you post a picture of the other end?
Seems like I've seen this before, where it is rusted in on the splines, and someone suggested spray in wd40, or penegrating oil, blocking off the eccentric hub, and tapping it thru with a plastic/rubber mallet
Which is why I would like to see the other end to see if there was some other "modification".
Discussion Starter #8
I ll try it and let you know....its stusk for good and i dont know why.it supposed to take it apart with out any force.
1 - 8 of 8 Posts
