1 - 2 of 2 Posts
I have zero response in the pedal.
I have bled the system 5x.
I have removed the caliper and flipped it up in several positions.
I have bled and reverse-bled them. Nothing.
There is a "sucking-air" sound coming from my rear mc.
I am thinking of going to my Ducati dealer.
Thoughts?
I had a similar problem with bleeding my rear caliper. Had to remove the caliper and place it on the top of the rotor to bleed it.
This allowed for the bleeder screw to be on the top and properly let the air out of the system.
I used the rear pedal to perform a manual bleed.
Rock hard pedal after that.
However, this all started because my master cylinder had failed.
1 - 2 of 2 Posts
