1 - 20 of 60 Posts
Hey guys, been searching around both here and on Ebay & Amazon but just keep confusing my self even further.
Im looking for a rear stand for a Single Sided Swing arm Duc, an 848 to be exact. I really only need it for cleaning the chain and waxing it. I dont track and most my maintenance is done by the dealer. I dont need anything to fancy just some thing inexpensive. I know, inexpensive and Ducati go hand in hand like a fork and electrical socket.
Is it safe to assume that the $150-$200 range I keep seeing, is what I should be expecting to spend for a new rear stand?
Im sure this is a very noob question, and i apologize up from like Chris Pratt for Jurassic World.
No I dont have the spoolers/sliders. I honestly havent seen them on an 848/1x98 before. I had a set of stands that used spools before but I sold them when it picked up the 848. Go those for $85 new too.
Lol @ Chris Pratt apology
Can't go wrong with Pit Bull! Not sure if the 848 requires two different sized pins like my 1199 does (one for chain side, one for the open side) but you'd want to research that. If your only intention is to just clean the chain and never to remove the wheel then you could save some money by just ordering one of the pins instead of both.
When the UK Ducati Challenge as it is called now, was the Ducati 848 challenge absolutely every team would use the Ducati Performance rear paddock stand, bar none. The factory superbike teams use them also.
Paddock Stand - Rear - by Ducati Performance - Ducati Motorcycle Parts, Ducati Motorcycle Accessories, and Ducati Apparel & Fashion from A&S Ducati ( I'm sure better prices are available, I'm in the UK and just used that link for an example of the stand I am talking of )
Now id you don't want to spend that kind of money then you want to look for something which copies that basic design. Simple to use single-handedly ( although at the racetrack you are never alone )
You especially want to pay attention to the rear loop of the frame and ensure that it is raised off the ground because: Fingers.
But it's just a tubular piece of steel so many will do the job. After prolonged and heavy use the wheels even fall off the DP model but that's easily fixed with a new spring clip washer which is the bit that pops off.
Pit Bull is best because it's reversible. If you were ever feeling froggy and got both pins (if 848 requires it), you can lift it from both sides of the axle. The DP stand doesn't look reversible. Not without undoing nuts/bolts to swap sides. And the PB is much cheaper. Attached are pics showing the PB's reversibility.
If you get the axle sliders with the spools then you'd be able to use the traditional stand like you had already sold.
Land vehicle Vehicle Motorcycle Motor vehicle Automotive tire
Land vehicle Vehicle Motorcycle Car Motor vehicle
What about one of these?
Wheel Jockey : Home Page
Motogpclaude is right, but there are a w ways to achieve it.
I bought myself a set of spool-shaped rear axle sliders protection cheaply from ebay (was around $20-$30) for track use, but it is also suitable for normal rearstands for spools.
That's a good value, double-use, and rearstands of that type are a whole lot cheaper than Ducati-specific rearstands.
Disc brake Tire Auto part Wheel Vehicle brake
Discussion Starter · #18 ·
Do you have a pic of the other side?
1 - 20 of 60 Posts
