Just like the title I replaced the belts, shimmed to correct gaps on my 08' 848 and now I am having an issue while running at about 5k rpm. Went on a 1k mile trip and during the last 100 miles I noticed at about 5k rpm the power drops out to where it almost dies. If I give it a little more throttle it will clear up. The exhaust sounds a little different as well. I do own a VDST and I reset the tps after the belts.
The other odd thing is during a couple starts it hesitates, the clock and trip reset. Try again to start and everything starts like it should. The battery reads about 13.0 sitting and 14.3 running.
Also does anyone know where I can purchase the plugs/cable to add length to the ecu cable. Sure would be nice to have the vdst without removing the panel.
Beginning to wonder if I purchased a Lemon.
Thanks for any help.
