This is a plea for help from the technically minded among you.
I've been having a problem with my 1098R where, when you clutch in coming to a halt in the city the revs seem to stay at around 3k for several seconds, before dropping back to idle. Similarly, if you give it a blip at idle, it will sometimes do the same thing - sticking at anything up to 3.5 or 4k revs and often for several seconds. I find though that, in the former case, if I kick it into neutral, the revs will normally drop pretty quickly.
I've just got the bike back from my mechanic, who has reflashed the ECU, played around with the air bleed & mixture, as well as the spark advance - and the bike is generally running noticeably better as a result - but it has not fixed the problem. It's slightly improved, but still there, with the revs just sticking at a slightly lower level and maybe dropping to idle a bit more quickly.
The problem seems to be more pronounced when the bike is hot - but that's about the only other piece of info I can provide.
Has anyone had this problem & can you suggest solutions? All thoughts appreciated. :violin:
