1 - 2 of 2 Posts
Hi all,
Does anyone know the procedure to read the EOBD codes for a SC1000. Can you do it without ducatidiag and a OBD2 cable?
I went for a ride in the sunshine yesterday, and parked the bike for a bit. When I went to restart it the EOBD light flashed and then remained on. I eventually roll started the bike and got it home.
The EOBD light did get back to normal later but it seems to have some sort of intermittent problem. I turned the key holding down the LHS button on the cluster but this did not display and error code.
Any advice would be really appreciated. If anyone wants to offer some advice on what of happened I can confirm that the cluster sweeps normally when the key is turned and that the battery is charging. :(
I hope my bike is ok while the summer is here.
1 - 2 of 2 Posts
