see how to set the belt tension with no special tools!!!
Finally after a couple of months since I've had this idea, I made a report so you guys can follow and do it yourselves!!!!
The principle is to put each cyl @ tdc end of compression stroke when the cams are @ rest and somehow check the slack on the belt......this is how you can do it yourself without any fancy tools and be pretty close to factory specs:
First, remove everything needed to get to the belt cvrs and remove them, then remove the coils and spark plugs.
Second, align the green dot in the layshaft pulley with the mark in the clutch cover, put an screw driver through the spark plug hole and rotate the crank (bike on 6th gear, rear tire on the air) back and forth to make sure you are @ tdc, the cam's slots should be align with the head surface to make sure they're @ rest and you are @ tdc on the final of compression stroke.
Third, mark the cam's pulleys to know your front cyl cam timing alignment marks, it'll look like this.......(layshaft pulley is already marked from factory, the cam's pulleys I did with witheout).......
see pics 1, 2, 3.
now you can remove the belt to do your valve adjustment by unloosing the 12mm nut on the eccentric adjuster and remove it or readjust the belt (will show you later)
Fourth, find tdc on rear cyl with the screw driver through the spark plug hole but make sure you are @ the end of the comp stroke (cams @ rest, cams slots will look exactly like on the front cyl, cam's slots align with the head surface, shaft pulley will be aprox 1/4 of turn away from green dot), mark them, this will be your rear cyl cam timing alignment marks.......it'll look like this....
see pics 4, 5, 6.
now you can remove the belt to do your valve adjustment by unloosing the 12mm nut on the eccentric adjuster and remove it or readjust the belt.
Fifth, to adjust the belt we'd need a hertz reader (should be @ 100hz, not lower than 90) so I'd figured if I can adjust it with the proper tool and then measure somehow the slack on the belt It'd be pretty accurate, so after trying different methods I came up with the perfect tool, a 10 mm wrench!!!!!
So the ides is to center the tool on the middle and push up and down on the belt to check the tension, It'll look like this........
see pics 7, 8, 9.
After adjusting the belts with the wrench method I rechecked them with the Hz reader..........
see pic 10.
Sixth, if you removed the belts you'll have to do the rear cyl first, align the timing marks, then put the belt, then the adjuster and the 12mm nut with its washer, then put a big flat screw driver between the nut of the adjuster and the ID ring to rotate it and tension the belt and gently tight the nut (this will allow you to have some tension and readjust it as needed).
Once you get to the desired tension then torque the nut to 26NM but holding the adjuster @ the same time (it might twist and you'll have to start over with the adjustment).
Before you put all back together rotate the engine slow by hand to make sure you didn't miss the alignment marks, it should turn over smoothly without any problems.
Seventh, put it back together and go for a test ride!!!!!!!!!!!!!!
see pics 1, 2, 3.
see pics 4, 5, 6.
see pics 7, 8, 9.
see pic 10.
