Hello, everyone. I unforutantly low sided my precious 2011 848 on its left side. Good news it was mostly cosmetic damage to the left mid fairing, a bent shifter, and busted mirror. I replaced the shifter with an ebay one and thought everything would be dandy so i go for a ride but the bike wont shift up unless i use a lot of force and it will only shift up so far like it "hits a brick wall". It shifts into first fine and neutral. So ive done my research and the consensus is it is either the clutch system or because i dropped my bike on the left side a shifting fork issue. The first thing i do is flush the clutch system but run into the same issue as before so I pop the left case off and discover that everything looks as it should and is not out of alignment. Im not sure what next to try so any help would be awesome. Maybe im just missing something obvious. Could it be the shift rod or something with conjunction with the new shifter? I dont know any ideas before i seal it back up? Thanks in advance.
