1 - 20 of 38 Posts
2016 Ducati 1299S, 2015 KTM RC390, 2015 BMW R1200GS, 2018 KTM 300 EXC TPI
Yep, just did the upgrade a couple months ago. Bought the kit from here: Home. Also bought a carbon bracket from member VJ020. No issues with either transaction, installation, or function.
Ive installed a few of them now. 848, 999, 1098, and this week a Hyper 1100.
There are some technical advantages of the series MOSFET over the older FH020- I dont know how those will play out long term since this is a newer part, but if you have the money...
I would also suggest relocating the R/R to the right side of the bike. There is a TON of room, and you can put this thing in the airstream and away from exhaust heat altogether.
Use the Triumph/Roadster extensions harness.
SH847 is relatively new and still not well-documented amongst sport bikes with high RPM application. At the same time, I have not yet documented any negative effects using that regulator also ; so you should be fine if you decide to choose that route (as compared to the previous model SH775 designed for cruisers, which is well documented to fail when used at high RPM's)
The reason I decided to go with FH020 was because it is the number one most commonly used regulator on all super sport bikes (panigale, r1, cbr, s1000RR) for the past 3 years. It is considerably lighter, smaller, and almost half the cost of the 847. I am still trying to find answers why the new and redesigned ducati v4 panigale, gsx-r and CBR fireblade did not use the SH847 - if we were to assume its better than the FH020.
A few notes-
Ducati's are not exactly "high rpm sportbikes". The avg Ducati spends much of its life between 3k and 7.5k rpm. Id call that almost a cruiser.
Also, Ive seen the SH847 working on the dyno up to 12,500rpm, with no excess heat or voltage fluctuations.
The *apparent* limit of 10k rpm- even if it was true- wouldnt matter in this case, unless you plan on running for extended periods of time over 10k rpm. With the possible exception of Daytona, where are you anywhere near redline for more than *maybe* 2 seconds?
There is a good reason why these are not yet common on Sportbikes- the lead time for incorporating these into an electrical system at the OE level is quite long, both from the electrical engineering side, as well as the physical location, and finally costing.
I run FH020 on a few of my bikes and they work great, so I still recommend them when space is at a premium, or cost is a big factor. SH847 is a lot more money.
how hard was the install and to bring over the harness to the other side? i order the T2500676 harness as well, just deciding between these two rectifiers :D
Discussion Starter · #8 ·
That makes sense, i would like a ease of installation as well, could you pm me the price of the bracket as well? i dont need cf, alu would suffice.
The sh847 looks huge, it is impossible to fit it without rerouting i suppose?
Discussion Starter · #9 ·
A few notes-
How is the reliability of the fh020 been so far?
Its fairly simple if you are mechanically competent. Making a bracket and doing the install took me maybe 2 hours total?
SH847 is maybe 2cm longer than FH020, so it wont fit where the stock regulator goes.
FH020 fits in the stock location with some cutting of the battery box- but really- you would be MUCH better off moving it to the right side.
The real issue is that there is *virtually zero* airflow over the R/R in the standard location.
Just relocate it. Spend the money to do it right the first time.
Cry once.
With the bracket from VJ020, I put the new R/R back in the stock location. I happened to have the battery box and wiring harness off the bike at the time, so my experience was a little different than just replacing a unit on a fully assembled bike. But I had zero issue with putting it all together.
Jason have you had any trouble with the heat from the R/R transferring to your aluminum bracket being so close to the plastic cam cover?
I `m considering a carbon fibre bracket.
No- and Ive measured it using a FLIR camera as well as a simple Fluke temp probe. These were done on dyno, and after a 20 min test ride.
One of the main benefits of the MOSFET R/R's is that there is much less heat created.
I dont know how much additional heat you would need to see to worry about an aluminum bracket, but I imagine it would be in the triple digit increase range.
That simply isnt going to happen with one of these R/R's. Ever.
Discussion Starter · #15 · (Edited)
Ive personally installed between 30-40 of them over the last 10 years and have never seen one fail.
This is the main reason that I *always* recommend the Shindengen stuff instead of the aftermarket versions. Their QC is just very, very good.
(Obviously that is anecdotal so take it FWIW.)
Now after hearing this, i just feel like getting the fh020aa and call it a day, does the panigale comes with a fh020aa as original?
Is Shindengen the manufacturer for the oem ducati/yamaha etc r/r? Just wondering thou there is a panigale 1199 breaking for parts and i could get a deal on the rectifier thou.
Discussion Starter · #16 ·
Cry once.
Yea just got around removing the damaged R/R, realized there is 0 airflow to it :( but i guess the i am only going to ride it 600 miles max a year,i just collected the bike on saturday, its my first ducati and so much to learn about it.
You can see the burnt wire on the rectifier, but it also damaged the wire on the bike side,the previous owner had direct wire it, any idea what connector and crimp do i need to get? also could i ask what is this long black tube? there seems to be a small hole in the bottom and had some oil leaking from it :O.
Thank you so much, and sorry for the multiple questions.
It does, and they are.
Probably better to buy *new* so you know that it actually works, but ok.
Correct, SH847 replaces the 775 and is robust against higher rpm application but nonetheless still designed for the suzuki cruisers (boulevard?) in mind where idling rpm's are seen for the majority of the time and where the 847 should shine. I do believe where the 775 would fail, the 847 should be fine on most sport bikes. However there has been no users documenting the 847's performance on track thus far and oddly enough, none of the sport bikes rolling out this year have adopted the 847 for reasons unknown. Therefore, if you do plan on riding your ducati frequently at the track (which I do) where sustained high rpm is common, I would say the results are still unknown on the SH847. Given that the 847 is nearly 3x (or 5x in my case) the price of a FH020, I figured the odds were better such that I would have to replace 3x (or 5x) failing FH020 before I replace one 847.
Second, the battery box does not need to be cut to fit the FH020. It is a direct replacement should you decide to go back to stock, nothing is changed.
I actually purchased my Fh020 from a wrecked panigale with about 1200miles so it was almost 1/5 the price of a 847. A no brainer if you ask me! Stores like rubbersideup.com frequently part out new/totaled bikes for low prices.
Initially I wanted to reroute my regulator to the clutch side as Jason did, but was a bit wary about 1) extended wires (personally I believe shorter the wire and less connections, the better) and 2) exposing the extended wires directly over top of the exhaust manifold/header. I was worried the exhaust would melt the wires
Discussion Starter · #19 ·
Thank you so much for the replies, finally received the r/r and the harness from triumph but ran into a problem now, as the picture below, the triumph harness is a male and my stator wires, 2 is male and one is female, any idea whats the term for this type of 'female' connector so i could crimp the new cables and get the correct socket?
Been searching the internet for the whole day and still couldnt find a term for this socket :(
Just remove the plastic terminal from the stock Ducati R/R and install it on the end of the Triumph R/R harness.
You shouldnt cut anything- just remove the plastic part and swap it over.
1 - 20 of 38 Posts
