This is what I did to stop the inadvertent falling over. The problem lies in the stock stand's inability to "overcenter" far enough to stay in the down position. I notched the stand a bit to allow it to go further forward. In the pic you can see the notch at the upper left on the stand. It mates with the "ears" on the bracket, which can be seen in the pic. You also have to open up the inside radius of that little bracket which allows the springs to clear the pivot when in the down position so it can fully travel to the stop. Or make a new one out of .062" SS as I did. I would highly recommend that you file the notch a bit at a time and try it without the springs until you get it right. That thing is not the most robust piece and going too far might stress it beyond it's breaking point. Anyway it works for me and no more accidental falling. If you look at the pic of the bike you can see the diff in angle between stock and the mod.
Lee
Lee
