Gents,
I have started to have an issue on my '11 1198 with 17k miles. For some history the sprag was replaced at 9k miles, twice, the engine was blueprinted and all that fun stuff at 13.5k miles at Ducshop (LOVE THEM). At the moment I am trying to prevent having to take it all the way back to Ducshop and give Mark some more money
Continuing on, I have swapped out the battery with another shorai one, I even swapped the battery with a OEM one from a 1098 that is super strong on that bike and when swapped with the 1198 just turns over or tries to start and then doesn't fire. After a few tries of starting a slew of error codes come out. The following have came out, the injectors are most recent as this happened after I dismantled the battery box cleaned up all the connectors and then put it all back together again.
LAMB 6.1 Lambda sensor error
COIL 10.1 Horizontal cylinder coil error
COIL 10.2 Horizontal cylinder coil error
COIL 11.1 Vertical cylinder coil error
COIL 11.2 Vertical cylinder coil error
INJE 12.1 Horizontal cylinder injector error
INJE 12.2 Horizontal cylinder injector error
The engine hasn't started to make the sound of a sprag going out, however, I am afraid it will start soon. The only other reason I can think of is that there is a short in the wiring harness somewhere. Any thoughts are appreciated.
Thanks,
Nick
Thanks,
Nick
