^here you go.... Dan Kyle knows about Ducati suspension set-up....................................... not a self proclaimed "internet expert" .... This post has been posted on numerous websites..... Lotsa info here, take your time and enjoy.....
Site Sponsor
Site Sponsors
PipPipPip
Posted 05 November 2009 - 09:44 AM
BEST setup for a 848 1098 1198
Kyle 30 MM offset triple clamps
Ohlins FGRT803 forks or
Comp 12 clicks out
Rebound 12 clicks out
Revalve of the OEM Ohlins forks to the same spec as the FGRT803 forks or
Comp 10 clicks out
Rebound 10 clicks out
Oil level with spacer installed 145 MM
Oil type Ohlins 1309 19 CsT @ 40 Degrees C
Ohlins 25 MM Cart kit for the Showa Forks
Comp 2 turns out
Oil level 165MM
Height of forks using Kyle 30 MM offset triple clamp:
measured from the top of the triple clamp to the seam between the fork tube and the fork cap 6 MM to 13 MM.
The 13 MM will turn faster and be less stable.
Start in the middle 9 to 10 MM.
The heights will vary with rider preference and tire height differences.
Different tire brands have different diameters.
Kyle Track Link
Our track link requires the use of the DU788.
We mod the shock, making it shorter and changing the valve spec.
We have valve specs for the standard length OEM swingarm and the longer race swingarms.
With our track link and the OEM swingarm we start the damping settings at 10 click out for Comp and 10 clicks out on Rebound.
We also require a shortened Sato Height adjuster.
This will be set to about one thread showing on each end.
Using the ducati height adjustment measuring tool, we set the ride height at 235 MM, with a range of 230 to 240 MM.
Using the tool, this is measured with the rear of the bike FULLY extended, meaning there is NO weight on the rear wheel.
The measurement is taken from the top of the tool to the center of the rear axle.
Wheelbase length show be as long as possible.
The numbers measured from the center of the swingarm pivot bolt to the center of the axle should be as close to 504 MM as possible, with a range of 496 mm to 504 MM.
With the long swingarm the number is 510 MM with a range of 505 to 515 MM.
Rider sag with our Track Link should be:
Front 40 MM
Rear 30 MM.
In my opinion,
You have a number of things that are not so good on a stock 1098S.
They are in two parts.
Suspension.
Geometry.
The two can and do overlap, meaning that adjusting one can affect the other.
The one thing you want to be careful of is not adjusting one to fix the other.
The first thing to be corrected is spring rate and spring preload.
One more thing, IF you have the OEM 80 Nmm rear spring on your Ohlins shock and your Ohlins dealer told you to add preload, he does not know anything about the 1098S.
The OEM 80 Nmm spring already has too much preload on it.
The front fork springs are 10.0 Nmm
Depending on your weight they may be right, too stiff or too soft.
The same with the rear, but whatever the rear spring you use, you must reduce the spring preload by machining the preload nuts.
The OEM shock and forks are OK for street use, as far as the valving spec. But for ANY track use they are not any good.
You can revalve the OEM shock and forks.
Or replace them with the FGRT803 forks and the DU788 TTX36 Rear shock.
Here are rear shock spring recommendations with the OEM link.
To get the recommended 12 to 16 MM of spring preload the two spring preload nuts need to be machined. The plastic one on the 1098S will need to be replaced with an aluminum one.
1098 Shock Spring Recommendations
NOTE!!!!! This is with 12 to 16 MM of preload on the spring!!!!!!
Note weights are rider weight with gear, or take your weight and add 15 lbs for gear.
140-160 Lbs 80.0 Nmm
160-180 Lbs 85.0 Nmm
180-200 90.0 Nmm
200-220 95.0 Nmm
220-240 100 Nmm
240-260 105 Nmm
260-280 110 Nmm
For OUR Track Link stiffen rear spring by THREE 5 Nmm steps.So if you use a 90 Nmm spring with thye stock link we would go to a 105 Nmm spring with our track link.
These are the parts or mods I would recommend and the order I would recommend them.
Basics:
If doing any of the items below, or all, saves you from crashing ONCE, you have paid for everything and more.
If you are going to ride your bike at a race track, track day, or race day, it does not matter,
PUT ON RACE TIRES. I
Suspension
Install the correct springs for your weight.
Set the sag.
This is with the bike suspension fully extended and with the Rider on the bike. The measurement is the difference of these two points.
For the street:
40 MM Front
30 MM rear
For the track:
Front 40 MM
Rear with the stock suspension link 20 MM to 30 MM
Rear with the Kyle Race Link 30 MM
Bikes with Showa forks
Revalve with 20 MM valves Good
Install Ohlins 25 MM Cart kit Better
Install Ohlins FGRT803 Forks Best
Bikes with Ohlins Forks
For the street the stock valving rides well, it will have a lot of brake dive, and bike movement. Good
Install Kyle Superbike valving Best
Install Ohlins FGRT803 forks Best
Bikes with Showa Shock
Respring the shock for your weight Good
Install Ohlins DU515 or DU520 Better
Install Ohlins TTX36 DU788 shock Best
Bikes with Ohlins shock
Install the correct spring for your weight, Machine the shock spring preload nuts to reduce the preload on the spring. OK for the Street Good
Install DU515 or DU520 Better
Install TTX36 DU788 Best
Steering damper
With Ohlins damper Best
With no damper (848) install Ohlins damper
With base damper Install Ohlin’s damper
Triple clamp
Stock 36 MM Clamp OK for street use, you will find for track use the bike does not have enough trail and tends to run wide on the exit of a turn under acceleration.
Ride height with the stock 36 MM triple clamps will vary with the tires you are using.
The rear ride heights at this time should remain stock.
The front fork height can be altered.
As you RAISE the front ride height you are adding trail, more trail will allow the bike to hold its line exiting a turn. This by the way is exactly what the 30 MM offset clamps do.
If the bike is running wide you can raise the front of the bike by pushing the fork tubes down. This should be done in very small step, I would try 2 MM at a time. You can continue to raise the front of the bike by pushing down the front forks until the forks are flush with the top triple clamp.
As you raise the bike up it will require more effort to turn the bike.
As you raise the bike it will tend to “feel” like it is falling into turns instead of rolling into turns.
Or
You can install a Kyle 30 MM offset triple clamp, this adds the needed trail, and shortens the wheelbase which allows the bike to turn with little effort.
With our 30 mm offset clamps the fork height should be between 6 mm and 13 MM above our clamp. This again needs to be fine tuned depending on tires And rider preference. Again adjustments should be done in 2mm increments.
The 6 MM to 13 MM is measured from the top of our triple clamp to the seam between the fork tube and the fork cap.
Depending on the Tire you may have some rubbing if you are running 13 MM.
Suspension 101
Let me go over some basics on suspension. As if the basic stuff is not right no matter how much adjustment you do it will never work, Example it you front tire is at 10 PSI and the Rear 50 PSI do you think you can make the bike ever work right??
But everyone knows about tire pressure, the problem is everyone does not know about suspension, and must "gurus" do not bother to explain anything, a lot of times it is because the "gurus" do NOT KNOW.
My experience is if they cannot explain it to you, run away.
First always adjust your spring, do not tinker with the damping adjustments until the springs are right.
Front sag with rider 40 MM range 35 to 50MM
Rear sag with rider 30 MM range 25 to 40 MM.
Do not do anything until the springs and sag are right.
Now if, like in this case you are bottoming the bike, do not rely on a zip tie to determine this, if it is bottoming you will feel it.
The way NOT to stop bottoming, is more preload and or more compression damping, while this will slow down the dive it will make the bike ride harsh and not absorb bumps.
The way to stop it is by raising the fork oil level.
What does this do, the oil level does not have anything to do with the damping, as long as the fork valves are covered in oil they will work.
What changing the oil level does is REDUCE the amount of AIR in the forks.
Remember as you are compressing this air the PSI is building, just like more air in your tires, the more the forks are compressed the higher the PSI, the stronger the air spring.
This AIR is a powerful progressive spring, the less air the more powerful this air spring becomes. The great thing about the air spring is that is does very little in the first 75% of the fork travel, but when you approach bottoming out, this air spring acts as a second spring, holding the bike up. Without having to have a too stiff steel spring.
When adding oil to do this it MUST be done in very small amounts, usually 10CC per fork leg at a time. A very small amount of oil will make a big difference.
Rising rate suspension
What is it? Here is a good basic definition (taken from f1technical.net) with a few changes.
A suspension system where the spring rate increases when the wheels move further in its travel. This action can be accomplished by configuring the geometric shape of the suspension, by using springs which change tension as they are compressed. The purpose of a rising-rate suspension is to maintain consistent ride and handling characteristics under a variety of situations: loaded or unloaded, straight roads or curves, and smooth roads or bumpy.
Ok, I will try and give a description on what is really does.
You have a rear wheel. This wheel has a travel usually around 120 MM on a Sportbike.
You have a shock, the shock travel is usually around 60 MM.
The two are connected by at least one link.
The link can have different designs allowing it to be Linear, meaning for each 2 MM of wheel travel the shock is travelling 1 MM, a 2 to 1 ratio.
Or you can design the link to be a progressive or rising rate link.
With a rising rate the options are endless. You can design it to do almost anything you want.
What we usually see is the travel, thru the first 50% (60MM) of wheel movement is very linear, meaning the for every 2 MM of wheel travel the shock is moving 1 MM.
Well what is happening in the next 60MM of wheel travel?? This is what is different.
What you may have is 60 to 70 MM of wheel travel the shock is moved 1.3MM
70 to 80MM of travel the shock is moved 1.6 MM
80 to 90 MM of travel the shock is moved 2MM
90 to 100 MM the shock is moved 2.5 MM
Etc
So what is happening, the shock and shock spring are moving more, they are moving at different ratios compared to the first 60MM of wheel travel.
So while it may take 60 lbs to compress each of the first 10MM wheel movements.
10MM 60 lbs
20MM 120lbs 60 lbs more
30MM 180Lbs 60 lbs more
40MM 240lbs 60 lbs more
50MM 300lbs 60 lbs more
Now it changes
60MM 78lbs more instead of 60 more 60lbs X1.3=78
70 MM 96 Lbs more 60 lbs X1.6=96
80MM 120lbs 60lbs X2.0=120
So what you feel on the bike is it takes more and more weight to compress the rear end.
This is great when you are selling a bike and have no idea how much weight is going to be on it, could be 120 lb rider 180 lb rider or a 180 lb rider with a 140 lb passenger. As this rising rate suspension can handle the different weights without bottoming out, which can cause a loss of control.
But when you know what the rider weights and it is say 180 lbs it works like crap as the rider does not weight enough to use all of the suspension.
As far as that 180 lb rider goes the suspension is pretty much doing the same as bottoming out, the suspension cannot use all of the available travel and stops moving, this causes a loss of traction and the tire, under acceleration, spins.
So what do we do, we make a new link that is more of a linear rate, less rising rate install a spring on the shock that is also a linear rate spring, and correct for that persons weight, and we get a more compliant suspension, that can use most or all the available travel, giving us more traction, hence the advantage at a track.
The advantage of these clamps is mostly at the race track, doing track days or racing.
The stock offset is 36 MM, these are 30 MM.
30 MM offset adds 6 MM of trail, this allows the bike to finish the turn better, allowing you to get on the gas sooner and hold your line better as well as better "feel" for what the front end is doing.
That same 6 MM change shortens the wheelbase making the bike turn faster and with less effort
53/53 MM Short stem
for 1098 Base, 1198 Base or any of the 1098/1198 series for use with the Ohlins Replacement R and T fork the FGRT803.
53/53 MM Long stem
These are for the 848 stock forks or the 848 using the FGRT803 forks.
53/56 MM Long stem or short stem.
These are for use with the FG511 Ohlins R and T forks.
This would be for the 1098S, 1098R, 1198S, or any 848/1098/1198 that you are mounting the OEM FG511 forks.
