Electrical issue... Need help!
Some time without turn the motorcycle on and the battery discharged. I tried to turn on using a jump start battery many times, until everything electric just died. No lights, no gas pump sound. I checked the fuses and the key fuse was bad.
I replaced the fuse and the battery, turned the key on but I still don't have the lights. The dashboard keeps blinking very weak, and I can hear the gas pump working.
What can be the problem? I checked all fuses and it is all fine.
Thank you
Thank you
