I have an '08 848 that's missing/snatching off throttle opening. Has had cams timed, valves etc done, Akra end cans, Hi flow air filter, exhaust valve defeated, DP ECU, PCV. I think the prob is, the DP ECU map is standard, which I understand is never going to be correct & the PCV has one of their standard maps as well, straight off their web site. The bike goes great other than this prob that makes it a pig to ride in traffic & not great on the track getting back on the throttle out of corners. Figuring a good dyno tune with a custom map for the PCV might help. Can anyone suggest a good experienced Dynojet/Ducati tuner based in Sydney. Thanks!
