I have just replaced a set of Termi carbon tubes from a 70mm system that had less than 3000K on the clock!!!
That's just not good enough for what you pay for the full system!! Has anybody else had a problem like this?
Here are a few pictures of the burnt cans and the new carbon RaceComp replacement tubes that we make.
These tubes also fit the OEM Ducati alloy cans if anybody is doing the cat removal and straight through race style modification.
RaceComp's cans are covered with a heat foil inside, that helps to reduce burning but if the packing is not properly done they too will eventually go brown, why don't Termi do this?
