2012 or 2013 corse? Or is the ECU map the same for the two?
I can't get a Microtec ECU because they don't have the map for the Corse harness...
Will not work YOU HAVE DTC in your Corse ECUsame map - no diff between 2012 & 2013
huh? there is no diff between the 2012 corse ecu and the 2013 corse ecu. not sure why u pulled my quote in? unless i missed somethingWill not work YOU HAVE DTC in your Corse ECU
