1 - 9 of 9 Posts
Drained the oil today at 1500 miles and this is what I found. Black rubber like chunks, and metal particles in the oil.
History of the bike: 2014 899, 1500 miles. Oil drained every 500 miles. 3 track days on the bike last summer and a few dyno runs over the winter. Installed a slipper clutch just prior to the dyno runs, and the bike has sat ever since. I assume the black rubbery bits are excess sealant from removing the right side engine case for the slipper install. Let me know what you guys think.
Yea I wouldn't worry, all looks normal. Once you start seeing big chunks stuck to the drain plug, that's when you should start to get worried.
Did you pull the screen from the oil sump? That's where I found some interesting stuff a couple of years ago during an investigation in to some chattering or 'knocking' noises on my 848 (turned out to be the bearing in the alternator side cover).
Here's a video where I documented all of the gunk that had accumulated in mine; if you did not remove the screen I recommend doing so, at least every other oil change.
1 - 9 of 9 Posts
