I have great tire wear on my Pirelli rosso corsa tires on my 899. After my last track day I noticed I have what I believe to be a slight rebound issue. I have trailing edge tire wear on the sipes of the tire. How do I dial this out? Should I increase or decrease rebound? FWIW my sag was set up for my weight and riding ability. I am using stock suspension. Thanks in advance.
Rebound's too fast if your trailing edge is raised -- the way it was explained to me is that your rebound's overly fast enough that you're skipping over the rear edge of the sipe. Also though, it was explained to me that some amount of the forward edge of sipes at the edge of the tire being lower than the trailing edges is common and it doesn't necessarily mean you have suspension settings wrong. With that said, you might want to slow your rebound down a click or two, see how that goes.
