What are the 998's true Hp & Tq numbers? and one with a good slip on Arrow exhaust. (I hear a lot of bs +- 30Hp)
Anything from 100hp to 130hp
The US 998 has 45mm headers, 50mm headers only came on the deep sump models: Euro Bostrom, Bayliss and 998sFE bikes.The technical reasoning behind the bike's low power delivery comes from the exhaust valve sizes, cam profiles and small diameter (50mm) exhaust headers.![]()
Are you sure about that? The book I have says 50mm headers on all the 998's, though the US model's may not have been counted for some reason. I can't imagine them running 45mm headers, that's TINY!!!!The US 998 has 45mm headers, 50mm headers only came on the deep sump models: Euro Bostrom, Bayliss and 998sFE bikes.
Positively.Are you sure about that?
you are completely wrong i have a 2000 748 with a 999r motor and it bolts right up with out any mods to the frame, the only things he needs to fabricate are the air box and exhaust just need to be modCan't really use a 748 frame with a 999 motor unfortunately. The vertical cylinder intake runs directly into the cross member of the frame. Some people cut that cross member out with a blow torch and re-weld it, but at that point, you're messing with the frame's rigidity. Plus, the swing arm pivot shaft is a larger diameter on the 999, so the engine won't rest on the shaft, this reduces strength of the rear end significantly. You can go the other way around and change the bearings on the swing arm + increase the hole size on the frame, but I'd be concerned about that because the 998 - 999 frame has more strength in that area.
Love the idea of building a franken Duc, I will be doing the same thing myself very soon. However, it's probably better to start with an appropriate frame, rather then trying to modify what you have to work. A 2001+ 748R or 998 frame will work fine for your desired outcome.
I have no idea how you did this without some serious fab work. The vertical cylinder intake boot barely fit's as it is, when you lower the engine (the testastretta has a shorter head) the boot winds uo being lower in the frame, obstructed by the cross member.you are completely wrong i have a 2000 748 with a 999r motor and it bolts right up with out any mods to the frame, the only things he needs to fabricate are the air box and exhaust just need to be mod
look at the pics there was no fab work need it the motor bolts right up, stop making assumptions when you clearly don't have the answer to his question and totally misleading the guy,here is a video of the bike start up now the bike is tuned and made 140 to the back tire with a 45/50mm exhaustI have no idea how you did this without some serious fab work. The vertical cylinder intake boot barely fit's as it is, when you lower the engine (the testastretta has a shorter head) the boot winds uo being lower in the frame, obstructed by the cross member.
