Hi All,
The bike:
-2012 Ducati 848 EVO
-Tuneboy EMS
-Exhaust valve delete with servo buddy to handle missing sensor signal
-K&N filter
-Slip on pipes
-LC-2 wideband controller and Bosch wideband sensor
The problem:
-Unable to register an AFR reading using the Tuneboy data logging software
Other relevant info:
-I know the sensor is working correctly, I can get a reading with the Innovate software, but not in the Tuneboy logging software:
171880
-Wiring is currently per Wayne's recommendations from the LC-2 controller output back to the factory harness. I verified that the voltage output from the LC-2 output is giving a valid voltage signal:
171881
-Did my best to follow all of the Tuneboy instructions step by step to ensure that this is not a setup or a logging process issue
The Question:
-Surely someone on this forum has gotten an Innovate controller to work with Tuneboy software on an 848 before. What did you do to make it work?
