I took my 1098S to Dynojet UK to have the UK's very first Power Commander 3 fitted to my bike and a custom map made.
They had just taken delivery of the PC3's on wednesday and they needed someones bike to obtain a base map and to see if there were any fitting issues before they could offer them for sale.
My bike had the full 70mm Termi exhaust fitted and they said that they needed a standard bike to make the base map and if I was willing to refit my standard system they would 'do me a deal'
I removed my full system and refitted the standard sytem and ecu and after Richard (great knowledgeable bloke) fitted the PC3 to my bike (Front cylinder injector is a pig to get to ) he did a test run with the PC3 set at zero.
There was a few dips here and there and the fuelling was not great and it gave a reading around 145 bhp at the wheel. He then adjusted the map to create a base map which made nearly 148bhp and got rid of the big dip at about 4,500 rpm and levelled the torque out along with the fuelling.
It was then time to refit the full system, 25 minutes to remove the original exhaust and refit the full system including ecu then it was back on the dyno for some custom mapping.
After an hour or so of thrashing the bike Richard was happy with his final results and fully explained his findings.
The air/fuel was all over to start with, it is now virtually flat, the torque has improved all over but especially in the midrange it has improved quite a lot and is much smoother, the final power figures were rather dissapointing to me as I expected more from the full system, It topped at 153bhp at the wheel, only an 5bhp increase from the base map. I hoped that it would be 160bhp as Termignoni claim an 8% increase. The buildbase superstock bikes are putting out 165bhp, the Dyno centre said this was because they run thinner head gaskets ????
Had a 200 mile run and the fuel consumption is still shit (90 miles then fuel light) torque is great, pulls like a train, but, there is such a flat spot at about 4.5k to 5k when on a closed throttle. If you back off to wait for say an oncoming car to pass, when you go back on the gas there is nothing there for a second or two then off she goes. Twice the bike sort of backfired when coming back on the gas ???
After speaking to Dynojet they studied the map and could see nothing wrong with it at all. They sent me the accelerator pump software and advised me to set the slider to 75% and the other two boxes to 20 and then try it out.
I looked at the map from power commander USA and it is different to mine, I do not know if it is set for separate cylinders while mine is a single setting.
Dans map looks good but here in the uk we run 95 octane fuel so I do not know what fuel the bike Dan used to create his graph.
Have you looked at the other maps Dan and how do they differ to yours. Would you advise having them set on separate cylinders ?
I see that there is an option in the Power Commander software for 'promoting to advanced' settings, what does this do or is it best to leave alone.
Here is my dyno map, I was told by the dyno guy that the air/fuel ratio is very good and that Ducati's in general rarely make massive gains at the top end ?
Dan can you see any flaws in this map, the bike feels good apart from the 4.5k problem mentioned earlier. I have set the accelerator pump module as they directed me but have not tried it out yet.
The red map is the base map they made after improving on the zero map which had a big dip at 4.5k.
