I really don't have much of an issue with the heat from the seat. But that being said I was bored the past few days so I decided to do an experiment.
Let me preface by saying this is not a final product. It is simply a test to see if I want to spend the time making something proper and durable. Also any experts please share some knowledge.
Anywhoooo,
I took an old pc fan. Not a cheapy mind you a pretty strong one from a friends gaming pc he built. He said it's a strong fan to move lots of hot air to cool his pc and could tolerate the heat for my test. He stated his processor can easily exceed 160 degrees Fahrenheit.
I made a bracket to mount it to and then mounted the bracket to the cross member the gas tank is attached to under the seat pan.
I then added a switch to turn it on/off. Wired it to a constant power source that only has power during key on (taillight). The fan is a perfect fit under the seat and the switch was mounted to my bracket and goes through one of the holes in the same cross member.
The results are noticeable. Measuring with a digit temp gauge we measured a 7-10 degree decline in heat when on. We did this same test at 5, 10 and 15 minutes of static running time (bike stayed park). Then I rode for 15 minutes and we measured again. Same results of an avg. of 8 degrees less heat when on. The most important thing though is the ambient heat feels like a greater decrease in temperature when on. It feels almost 15-20 cooler when the fan is on.
Here are a few pics. I know the underside is a bit dirty. Again, this is not a perm. product. We will test it's durability and see what we need to use that will withstand the high heat. But so far after 2 days nothing has melted and it still runs fine. Oh and it only cost $1.49 for the switch and 10 minutes to fabricate.
What do you guys think?
Anywhoooo,
