Hi!
I have an '09 Monster 1100 S.
I'm shopping for used wheels. Black with the red stripe.
I understand Ducati has a large & a small axle.
Which do I have & will a front wheel from a 1098 fit my bike?
Also, will a rear (single-sided) wheel from a 2010 Hypermotard 1100 fit? Axle hole on that wheel is 43mm.
Thank-you.
You are correct that there are 2 sized hubs. Yours is the small. The large hub bikes are the 1199/1299 Pani, Multi 12, 1x98 and Diavel. You'll find that most front wheels from all Ducati's will fit and all small hub rear wheels will fit your bike.
Wheels
Thank-you. That's helpful.
The front wheel I'm looking at buying is from a 1098, but from what you say about 'most' fronts fitting, I'll probably snag it while I can. It's nice. It's new, but way less than new to buy.
I'm a couple hundred miles from a dealer, and they can't give much advice on wheel fitment, apparently.
