technically the bike is only 18 months into service, so it's not necessary per the service manual. That being said I do understand the bike is actually pushing 8 years old.
Gates, the manufacturer of the Ducati timing (synchronous) belts, state that they expect this type of belt to provide full service life as designed, even if stored for
eight years on a drive under tension.
http://ww2.gates.com/IF/facts/documents/Gf000058.pdf
What this means to us is that for low mileage bikes that have been out of service for extended periods of time, or for bikes that see infrequent use but proper storage, belts need not be changed out based on Ducati's time limitations.
The eight year non-operational time limit is dependent on proper storage conditions of the bike as follows:
• Belts should be stored in a cool and dry environment with no direct sunlight – Ideally, less than 85ºF and 70% relative humidity.
• Belts should not be stored near windows, which may expose the belts to direct sunlight or moisture.
• Belts should not be stored near heaters, radiators, or in the direct airflow of heating devices.
• Belts should not be stored near any devices that generate ozone. Ozone generating devices include transformers and electric motors.
• Belts should not be stored where they are exposed to solvents or chemicals in the atmosphere.
Ducati could have specified an eight year belt replacement interval for belts that are known to meet this storage criteria – but this would shift the failure liability to the owner – so they wisely didn’t.
What I’m saying here is that you don’t necessarily have to blindly change the timing belts on low mileage bikes based on Ducati’s time limit schedule if you personally know the bikes full storage and operational history.
