Question to all of you guys with Woodcraft rear sets on their 1X98 / 848 bikes.There are two sets of mounting holes (within 3/4" range) in each foot peg bracket,so one can adjust these brackets lower or higher off the ground. Somehow I can't make it work in lower position because gear shift lever is touching the bodywork.It clears the bodywork in higher position without any problems.
Bike has OEM bodywork if that makes any difference.Is there a trick to make it work?
It would be nice to have foot pegs in stock position,since I don't have need for more ground clearance. Thanks for your help.
