1 - 3 of 3 Posts
I took the clutch slave off of my 916 and tried to put it on the 1098 and it won't fit on. I push it up on the rod but it will only go so far. It won't go all the way on. Is there a difference between the 916 and 1098? It was working fine on the 916.
Sure is, different rod lenghts
I have listed a few on ebay here is the item number for one and just use it to check out the other colors item# 260112536936
http://cgi.ebay.com.au/DUCATI-1098-...yZ102691QQrdZ1QQcmdZViewItem#ebayphotohosting
Dual O-Ring, billet CNC different anodized finishes
There is a picture with the instructions attached which will help you identify what slave unit you have. I include a spacer kit so it can be used on any model
Hope the picture helps clarify why yours wont fit
Cheers
1 - 3 of 3 Posts
