Stalling again!
1 reading
18K views 82 replies 37 participants last post by  grndcont
#1 ·
Well, here it is....I had the 2nd recall (voltage regulator this time) done and the bike stalled again. My bike was running 190 degrees but that shouldn't matter. I have the temignoni slip ons with a remap ecu, but who knows? I immediately tried to restart but would hardly turn over. I turned it off and waited a few minutes and it refired again?? I have had Ducatis for 7 years but this is getting old! :banghead:
#2 ·
Damn...that's a bummer. The voltage reg recall shouldn't do anything to the way it WAS running. I've got an S with the race ECU and full system so we're not apples to apples here but the VR switch didin't do a thing.
Still runs great...always has!:yo:
Let us know when you find somthing out.
Doug
#3 ·
It runs good at speed but it stalled when I pulled in the clutch so it almost sounds like some sort of fuel setting problem. It was a warm day and I tend to think it's a minor issue.....but still annoying! I will have to take it back and have them look at the map settings. Thanks for the reply!
#4 ·
Almost sounds like your ECU reset to prior settings. Your symptoms are just like the others that have had the stalling problem when the bike first came out. If it did reset...makes me wonder if it would also reset when changing/disconnecting the battery. Curious!:jerkoff:
Doug
#5 ·
if it makes you feel any better after I got the recall on my 848 it stalled twice on the way home(7mi), both times with the clutch pulled in coming up to light. Now about 300mi later and it hasn't done that, but has stalled twice sitting at a light in neutral, just shut itself off. BTW, never stalled once before the recall was done. I don't have an answer as of yet, I only have slip ons with the stock map. I agree that it is annoying, the dealer isn't much help; common sense says it is something they did since it never did it before. good luck
#8 ·
I am experiencing the exact same problem. Had the VR recall done, now I stall when pulling in the clutch or at lights. The engine would sometimes cut out prior to VR recall, but this was very different, during load while slipping the clutch - doesn't do that any more which is good, but yes, this is annoying. Several times each time I ride, such that now you're always paranoid sitting at a light that the engine is going to die! Damn these things, I want it to run right!
#9 ·
AT least they only stall coasting to a stop....mine stalled going 180km/h near a turn on the road and locked the back wheel solid (good pistons seal I guess!) putting me in an almost 108 degres slide...grabbed clutch,tail whiopped hard back straight and saved the day...sweat.
That stalling while coasting happend on my 97 TLS and Suzuki swapped ecus...effectively cured the problem while robbing me of 15 rwhp.
There might be a problem with the dash as well,if your dealer has a backbone and is willing to experiment,he could swap dashes with a demo and see what happens next.
#10 ·
These bikes are all fly by wire. The dealer, i should think, should be able to hook the bike up to a computer and have the bike tell the dealer what the problem is. My gut tells me that this is an ECU problem of some sort.
#12 ·
Ok.....different day, bike temp running around 165 (cold morning) and not one stall. I rode for about 1 1/2 hour (canyon and city streets) ride and nothing? I always run the 91 octane but I guess it's just unpredictable?
That's funny, because I took mine out the other day, rode ALL day, and not one stall either. It hards to take it to the dealer and ask for help if the problem is this damn intermittent. I dunno, hopefully it will just magically never stall again :p
#15 ·
When my bike stalled , I went to restart it and it barely turned over. The only way to restart was to turn off the key, wait about 2 to 3 minutes and then turn the key on and it starts right up as if nothing happened? I wonder if the battery itself is bad or the starter motor? I am running out of options. The VR recall didn't do a thing!
#17 ·
Mine only stalled twice in the first 595 miles. I had the dealership check it over and of course they could not duplicate the problem. Since the VR recall and the Akra slip-on's have been installed it's stalled 3 times in the last 60 miles. :confused:
#18 · (Edited)
had the issue when I first got the bike, although it already had a DP ECU with the full system
it was stalling, the dealer fix the issue by running it too rich, you can smell allot gas
coming out the exhaust. however when I got the PCIII installed the second dealer fix the issue
and my idle RPM went down from 1700 to 1400. so worst case get a PC III and a good map,
a custom one if you can.
#19 · (Edited)
just took mine out again today and its still stalling... at least it starts right back up though, it stalled twice when i was at one red light... im learning to just continuously rev it while it is clutched. im idling around 1250-1300 which i believe is about where it should be. i saved it a few other times from stalling by reving it, i really dont want to raise the idle.. it already moves to fast at idle in first when im in traffic.... getting to be a huge pain in the ass
Might just be me but 1250 seems a little low.
Never had an issue with 3 different ECU's (stock, full DP and Nemesis) idle at around 1450.
#20 ·
I think I finally got it figured out. I spoke with my dealer and explained the problems with the stalling and not being able to restart. The stalling issued is related to the ECU most likely. Even though it's a "race" version with the Termi slip-ons I think that when it gets hot it leans out the bike too much and drops the idle. I probably have to pay up for a power commander to piggyback on the ECU to dial in the fuel mapping.
The starting issue is most likely the starter which apparently was an issue for some of the '07 models, although it wasn't a "recall". My dealer is speaking with DNA and I should have an answer by tomorrow in regards to them covering this issue. I think I might upgrade the battery also.
Thanks for all the replies.....
#21 ·
may be a solution for the stalling issue
the owner of the dealership that i purchased my 1098R from did some research and ended up with a 3 page check list from Ducati that addresses this stalling issue. the most interesting item is cam timing and/or replacement of one or both cams if their Identification numbers don't match with what's described in the check list. service will take a good tech the better part of a day to do. if you need cam replacements be prepared to leave the bike for a while.
not great news but apparently Ducati knows they have a problem.
cheers...........SPOKE
#25 · (Edited)
That's the answer. Getting the cam timing set correctly makes hella difference how they run. Get it right and they'll run smoothly down low to the point that you can leave a stoplight at 1200 rpm. And they will have more mid range power. It's the cure that Ducati does not want to put up on a billboard as it's sooo labor inten$$$ive for them to eat. In the interim they toss the smoke and mirrors various band aids we have seen over the last two years.
Dial them in and it'll be a flawlessly diferent bike.
#22 ·
If it is still stalling try installing a new clutch line lol jk
or maybe seriously* could be your clutch master cylinder. :/
idk what else it could be. Have you also tried adjusting the idle speed higher?
#26 ·
stalling
New owner. Had VFR's (4) Aprilia, Beemers. Anyway, stalling
issue - cam timing makes sense, especially in the case of a high compression twin with mods. Touchy. My 1098 has stalled several times, and restarts so far. Interesting to note, though, the night before I picked it up, prev. owner could not get it started after storage. Said plugs were fouled (black). Cleaned them and got it started. Saw on another thread about rich mixture/fuel smells. Used to require 2-3 servo start cycles to fire - now I crack the throttle slightly and it fires and starts on the first cycle, even with OAT in the 30's. Seems to need a touch more air in the mix to be happy down low... 3,500 miles, full Termi/ECU.
#28 · (Edited)
+ 1 on the cam degreeing, it made a night and day difference in the way the bike performs. And i thought it was fantastic before.
I thought my stalling days were over when i had the full system installed, but towards the end of last year it started stalling every once and a while.
all 4 cams were out of time, intakes were the worst, 8-9 degrees retarded.
Now it starts with 1-2 cranks (cold), pulls like a freight train, has a rock steady idle @ 1400 and it revs silky smooth.
so far no stalling.
If your still under warranty have the cams checked out, preferably when your having the 7500mi service. They might need to be degreed or replaced. its 9 hrs to degree the cams, you don't want to pay out of pocket for that.
#29 ·
I went thru this all thru 07 with my first 1098. My dealer really stepped up and went beyond my service expectations, but the problem was never one they were completely sure they had cured. I have an 08 1098S now and it's a different story, it has stalled a couple of times in it's 5000 mile life. - but only a couple of times and spaced out over months.
The cam timing was thought to be the culprit with my 1098, and as Dr.No pointed out, it aint cheap or fast to degree the cams. I've heard that the problem is - some cams came with the bolt/holes misaligned (cam sprocket or cam - not sure which).
Finding which one is out, and degreeing them correctly is a big job, and one DNA would rather avoid on warranty I would think!
#30 ·
Another problem you may face is finding a mechanic who knows how to degree the cams correctly. They don't teach this at MMI. I had someone try to degree some 996 SPS cams in my s4 who didn't have a fricking clue at what he was doing. I went through 6 or 7 sets of plugs before taking the bike somewhere else. Just be sure and ask around for someone who has experience. With someone who knows what they are doing, the process should only take~ 4 hrs.
#31 · (Edited)
FWIW they do teach it at Wyotech. That said there is a difference between being taught how to do it on one engine on a stand with the dial indicators mounted vs. doing it on any of the many different motorcycles Ducati makes and like anything practice is the key to doing it in a timely and efficient manner. Some shops hardly ever have a customer that wants their cam timing done and some do it on a daily basis.
